Two MR in two different office, inter-communicate
James12
i have a request to set up our remote office with a new MR.
how do I route the traffic from the remote office to the existing office network?
current office using VLAN 10 with an MX 64 as our gateway.
The remote office will be VLAN 20.
DHCP service will be on our MX 64.
Can the remote office network route into the current network ?
DarrenOC
Hi @James12
you will require a concentrator for your MR at the Branch office to communicate back to at the HQ.
Do both sites currently have an MX? Can you create a site to site vpn or auto vpn between sites to route your traffic.
a few options but depends on your current setup
2 REPLIES 2
DarrenOC
Hi @James12
remote office only has a cisco router as the gateway.
