Turn off 2.4 GHz radio on one access point only
antmich
Hi everyone,
Title says it all ! I'm trying to figure out if it is possible or not to shut down manually the 2.4GHz radio on a Meraki AP.
I think it might be possible from ap.meraki.com, but is this configuration going to be overwritten by having the AP connected to the dashboard ? Is there a way to do this from the dashboard that I am not aware of ?
Thank you all in advance,
antmich
Inderdeep
I think you may use Band steering which will help you to leave 2.5Ghz while all clients will use 5G Band.
https://documentation.meraki.com/MR/Radio_Settings/Band_Steering_Overview
Else
https://documentation.meraki.com/MR/Radio_Settings/Transmit_Power_and_Antenna_Configuration
Regards/Inder
www.thenetworkdna.com
2 REPLIES 2
Inderdeep
Else
Regards/Inder
Your second option is such a game changer. Thank you ! It has been under my nose this whole time !!
