Transmit Power showing above RF Profile configuration
ebarnes75
Hello All,
I and a coworker have completed an install using MR46 Meraki APs. We have implemented an RF profile for the site which appears to be working and has taken according to the dashboard. The issue/concern we have  is that the Transmit power is showing greater than the Target Power. This is for both 2.4 and 5GHz. The RF Profile is a per AP profile with the power settings 2.4GHz 5-11dBm and 5GHz 8-11dBm. The Transmit power is reading 20dBm, which is concerning. Is anyone seeing this issue or can direct me to information to help troubleshoot this?
Thanks in advance.
3 REPLIES 3
You are sure you edited the profile assigned to the ap?
Did you wait a few hours?
Yes it was several days and it shows applied in the dashboard.
I would try reboot 1 ap to see if that ap obeys the settings after reboot.
Ofc  you could also log a meraki case
