There is no setting of walled garden and captive portal strength
Dear all,
I am making a click-through splash page and referring to Meraki documentaions.
I have an issue for redirecting from my splash page to google, so I want to set walled garden.
However, there is no setting of walled garden and captive portal strength of a SSID of my company.
I accessed the menu Wireless > Access Control but I could not find them.
I expect the setting like the images in this link(https://documentation.meraki.com/zGeneral_Administration/Cross-Platform_Content/Walled_Garden).
The only thing I can set is 'Association requirements' - Open, 'Splash page' - Click-through, and provide a specific URL where users will be redirected.
Help me to set WALLED GARDEN!
Accepted Solutions
Re: There is no setting of walled garden and captive portal strength
For me it appears as soon as I select Open in the association requirements and Click-through as splash page. It's just above the Client IP Assignment setting:
4 REPLIES 4
This only works on an MR. Are you using an MR?
To @PhilipDAth,
Yes. I use the model MR34.
I do not know what is wrong. Then where can I find Walled-Garden settings?
Dear, @BrechtSchamp
NOW I FIND THOSE SETTINGS!
I selected Click-through and tested Splash Page functions many times,
but I did not find Walled-Garden setting in a silly.
Just I did not see under after selecting Click-through. 😞
Thank you always.
