The Client needs to associeted to Meraki SSID with their user and password defined in Azure AD
AJDINI
Meraki SSID Access control - The Client needs to associeted to SSID with their user and password defined in Azure AD
Please, I need your help to know if is it possible to configure in Meraki to the Client get associated to SSID with their user and password defined in Azure AD.
I found links about the Meraki-Azure AD integration, but all these links only speak of the registration in the Cisco Meraki dashboard by Azure AD, but unfortunately I do not find any link about the possibility of configuring in Meraki that the Client get associated to SSID with your user and password defined in Azure AD.
Please, I look forward your advaice about this issue.
Thanks in advance for your help.
Alejandro
The system that WiFi uses (WPA2-Enterprise) and AzureAD doesn't support any compatible methods to do authentication.  Not a Meraki issue - a general issue.
You need to use a third-party solution.
Some people use Azure AADS and deploy an NPS server in Azure - but Microsoft doesn't support this configuration.  So if it breaks tomorrow, bad luck.
Examples of third party solutions include:
https://wiflex.eu/
https://www.cloudradius.com/radius-authentication-with-azure-ad/ https://jumpcloud.com/blog/cisco-meraki-radius-as-a-service
Hello Philip:
First of all, Thanks a lot for your answer. It was very useful your answer.
I told my Client about the request of posibility that "The Client needs to associeted to Meraki SSID with their user and password defined in Azure AD" and I mentioned yours advaices.
Then, they decided to ask me to find another posiblility to the users autenticate in Meraki with their user and password in AD. I keep you posted about this request.
Again, Thank you very much for your help.
Best Regards
Alejandro
Ajdini,
Surely if you're utilising Azure AD you have an on-prem AD server as well? Can you not use LDAP authentication and a RADIUS Server instead of trying to authenticate to the cloud?
Cheers
Alex
Hello Everyone:
Thank you very much for your answer.
Finaly my Client is thinking to choose another solution.
Again Thanks in advance for your help.
Best Regards
Alejandro Dini
