Suddenly, one SSDI says No Internet Connection on iPhone and iPad
EJN
All APs are online. Working OK on same SSID on Mac and Windows (posting this message from Mac on this SSID).
For some reason, iPhones and iPad are not connecting. If I change to a different SSID, they connect OK.
Restarted APs. Same problem.
Any points to where to troubleshoot?
Esteban J Nunez
School and Church
K-12 Education
6 REPLIES 6
Can you show the SSID configuration?
Can you ... ?
Esteban J Nunez
School and Church
K-12 Education
Attached. Other SSID with same configuration are working OK. It's only this SSID and it started today and only on iOS (multiple iPhone and iPad experiencing the same issue). But MacOS and Windows are working OK.
Staff: problem SSID
DM: working OK SSID
Esteban J Nunez
School and Church
K-12 Education
EJN
Detailed via of the SSID in question.
Staff SSID Settings: SSID Settings
Esteban J Nunez
School and Church
K-12 Education
The configurations are good, so I suggest you open a support case.
I renamed the SSID adding the word Old, and created a new one with the same name/pw and settings. iPhones able to connect again (automatically since name and pw match what's saved within iOS settings). Don't know what could have triggered this, but not going to research further unless it happens again.
Esteban J Nunez
School and Church
K-12 Education
