Sponsored Guest feature
rhmaidan
Hi, was searching for a way for employees to sponsor their guests in a corporate environment and stumbled across this link: https://documentation.meraki.com/MR/Encryption_and_Authentication/Sponsored_Guest, but apparently this is no longer applicable because I cannot find the option under the Splash Page Selection. Is there anything I need to setup before having this feature or is it no longer being offered?
Plus is there a workaround to have similar functionality?
GreenMan
Did you spot, within the Documentation, that this feature needs to be enabled by the Meraki Support team?   The feature only becomes available in your Dashoard after this has been done.    Details needed to contact the Support team are available through Help > Get help, top right of the Dashboard
While it's not quite the same, you might also want to consider this feature:   https://documentation.meraki.com/MR/Splash_Page/Self-registration_for_Splash_User_Accounts
2 Replies 2
GreenMan
Thank you so much for your support 🙂
