Searching for poe converter
MarcP
Hi all,
i am searching for a poe converter to get a MR74 online.
MS225 - fiber port -> to rj45 fibre poe converter (there will be only one powersocket) where I can connect my MR to get it online
or
MS225 rj45 port -> to fiber converter -> fiber converter to rj45 (poe - only one power socket) -> MR
Has anyone build something like this and can recommend a device?
5 Replies 5
DarrenOC
Hi @MarcP ,
is this what you're after?  Would be RJ45 to RJ45 poe injector.
https://meraki.cisco.com/product/security-cameras/security-cameras-accessories/security-cameras-acce...
@MarcP I think you want one of these:
EM-GTP-805A_V2.1.pdf (planet.com.tw)
They are available in the UK , but not sure where you are.
There are also other options made by them listed here:
PoE Media Converter - PLANET Technology
MarcP
Yes @cmr this is what I mean. Found a couple already, but not sure about if they are working good.
So, do you already have some in use and can recommend them?
We´ll need to place them into a stake in a couple of meters height (safe not to get wet or something 😉 ). -20°C to +40°C is possible
I use this one on my MR74,84,86 APS.  work great.  don't get too warm.  not too large
Bruce
Some thing like these? Media converter with PoE? Can’t say I’ve ever used one, but should be the answer. https://www.perle.com/products/media-converters/poe-media-converters.shtml
