Scheduling wireless
Al
Scheduling wireless
OK, I'm trying to set up scheduling on wireless on a Z1, and I guess I'm missing something.
Pretty standard; I want the wireless to be available to certain devices between 8:00 and 20:00.
I've set up a group policy with scheduling enabled.  I've assigned that group policy to the device.
It makes no difference, the device can connect wirelessly all the time.  What setting am I missing?
Thanks, Al.
Ben
You cannot schedule the Wireless on the Z1.
The group policy with scheduling applies to limitations or settings you can apply to your client during certain times of the day.
Cheers,
Ben
Al
Thanks Ben,  that'll be it then!!
Could I schedule a rule to block facebook, for example, between these hours?
Cheers, Al.
Ben
Yes you can. Configuration could be like the below screenshot.
Cheers,
Ben
Al
Hi Ben,
Many thanks for that.
Al.
