Reg. SSIDs and templates
SBhas
Hi
On a meraki dashboard, If I configure or remove a  SSID in one network template,  will it be reflected in other template configuration?
I need to disable or remove a SSID from one template and need to ensure it doesn't affect the other network templates
thanks
Bhas
2 REPLIES 2
GreenMan
A change in one Template does not affect another Template.   A change in a Template will affect all Networks bound to that Template.
SBhas
Thanks, Will give that a try...
