Reconfigured MR42 stuck on Orange to Green LED, does not reach Meraki Cloud
DubVee
I reconfigured a couple MX64s and MR42 for two new networks.  The MXs are online and seem to be working,  I have the MR42s plugged into port 4 with power adapters providing power (MX64 does not have POE).  The LED on the MR42s go from green to orange and back.  In the dashboard they say they have never connected to the Meraki Cloud and the SSIDs are not showing up.  What did I not do?  Thanks!
2 REPLIES 2
DubVee
Well, I may have found it.  Port 4 on the MX was configured for Internet.  After fixing that I'm making some progress.   🙄
NolanHerring
Sounds like you got it figured out
I was going to suggest trying another port, make sure its configured for access if its a simple single VLAN setup, otherwise make it a trunk port with proper vlans allows (SSID to VLAN etc.). I would recommend 25.13 firmware, i think that runs solid for MR42 from what I've seen.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
