Psion Handheld do not work
my customer had Motorola Psion Handheld. The RDP Session do not running. All so the ping didn't work.
Install to MR66. We tested ping whith a notebook and this running.
Who can help?
Best regards
Andreas
7 REPLIES 7
Re: Psion Handheld do not work
Can I get the model number? I had some issues with some POS handhelds connecting to the wifi, need to allow legacy a/b to connect.
Depending on AP firmware version and the capabilities of the haldheld client, you may need to try out decreasing the minimum bit rate to something less than 12Mbps (try 11Mbps) and/or disable 802.11r on the Wireless > Access Control page for that SSID in case the client doesn't support 802.11r and try that as well.
Hi Body,
see my photo.
Best regards
Andreas
Can I set 11Mb fixed on MR Access Point
When I trace the ping I have this result:
Start ping on Handheld --> AP (OK) --> Server (OK) --> AP Eth-Port (OK) --> AP Wireless Port (error) --> Handheld (error)
I hope understand.
thx for support Andreas
Meraki Alumni (Retired)
Well, this looks like more like a connectivity issue. Can you describe the settings you have on Wireless > Access control? If you have a password there is no need to post it here. What I would like to see what settings you use to make a recommendation based on that.
How far away are the end devices from the Wireless APs?
Leo Gomez
Hi Leo,
sorry for the delay answer. The end device is 1 m from AP.
We problem with MR33, MR66, MR74 and we think that is problem with the chip in the AP.
Now we have a dedicate TAC Ingenieur. I hope we can fixed.
Best regards
Andreas
@Andreas-B
Problems with old tech scanners is widespread, across all sorts of networks.
Put them on their own Wi-Fi network that has the oldest WiFi standards enabled (802.11a and 802.11b) and the original (weak) password security, and turn off anything remotely clever.
