PMS integration
msosa
PMS integration
   Hello, I'd like to know what is needed to develop in case where I want to connect a MR solution with the hospitality customer PMS, in my case  the PMS is TCA Innsist (http://www.tcass.com/productos-y-soluciones/tca-innsist). this would be my first project with Meraki for hospitality, so I'd like to understand specifically what is needed to do in order to integrate to a PMS (in general meaniing, regardless of the brand), and what should I ask to my development team to do.
   thank you in advance!
Regards
Mauricio
3 REPLIES 3
Unless you can find something already made, you'll need to use the Dashboard API:
https://documentation.meraki.com/zGeneral_Administration/Other_Topics/The_Cisco_Meraki_Dashboard_API
Thank you for your answer !!
If you think I helped it would be great if you could give me some Kudos.
