Optimal Wifi Coverage in a Campus Housing
BenjaminMulwana
We are looking for some information on the best way to setup Wifi in a Student housing complex.
 - What are the best RF settings people are having success with?
 - What are the best Access Point models for this type of situation?
 - What does the spacing look like in a complex like this?
 - Is there a Meraki Survey or design software that we can utilize?
2 Replies 2
DarrenOC
Hi @BenjaminMulwana
in all honesty you’re best engaging with a wifi survey company as they’ll be best placed to answer these questions and complete a survey based on your requirements.  Scrimp and cut corners at this point and you’ll regret it
Generally, in-room access points work better than access points in hallways outside of the rooms.  Take a look at something like the MR30H.
https://meraki.cisco.com/product/wi-fi/indoor-access-points/mr30h/
If you have areas where a lot of people gather (like common spaces) check our the MR56.
https://meraki.cisco.com/product/wi-fi/indoor-access-points/mr56/
Allowing everyone access is the easiest solution.  If you want to do per-user controls check out the Splash Access education system.
https://www.splashaccess.com/splashaccess-education-campus/
It allows students to onboard their own devices (smart phone, play station, etc).  It allows them to roam around a facility.  And it allows you to disable individual student accounts.
