Not able to configure Static IP on Meraki AP
Naresh_Bhardwaj
Im trying to give static IP address to meraki AP however its not taking it
 If i check in switch DHCP IP os mapping to MEraki AP MAC address
Please help
DarrenOC
Hi @Naresh_Bhardwaj
Take a read through the below document
https://documentation.meraki.com/MR/Monitoring_and_Reporting/Static_IP_Assignment_on_a_Cisco_Meraki_...
Below snippet is taken from it
"If the AP is not able to reach the configured default gateway on this static assignment, it will fail back to DHCP. Please inspect the static configuration and the VLAN configuration being used on the network if this happens".
Have you tagged the correct vlan on the uplink from the switch to the AP
Note: If a VLAN is specified in the static IP configuration, management traffic from the AP will be sent out with an 802.1q tag for that VLAN. In this case it is expected that return Management traffic should also be tagged appropriately.
@Naresh_Bhardwaj  I've got this same issue, have triple checked all of my settings and even got someone else to take a look and they couldn't work it out. I gave up in the end and statically assigned it on the DHCP server.
Many people ask me why I want them with static IP and thats because we run mutiple pieces of network monitoring software so using DHCP wouldn't work.
Keep in mind, a Meraki AP that is a mesh repeater must be DHCP addressed
