No splash page appears on devices
dgriffiths
We have set our guest WiFi SSID to have a click through splash page. However, when devices connect, they go straight on to the Internet and no splash page is shown. Looking on the Merak dashboard it shows the devices as "Not authenticated" however it works fine. We have another site which works fine and have compared the settings, and they look identical.
Any ideas?
12 Replies 12
Check this config:
The Captive portal strength should be set to Block all access until sign-on is complete.
It's set to Block all access until sign on is complete:
What authentication base are you using? Can you share an example? Does this happen to all customers? What operating system? Do you have any walled gardens set up?
By the way, what version are you running?
We have MR33 and MR42 accesspoint running 29.4.1
Version 29.4.1 is not stable, try version 28.7.1.
It is a Stable Release Candidate and as such fully supported by Meraki:
But, It's not stable yet. Try version 28.7.1. 😉
Happens to all customers, have tested Apple and Android devices. We have enabled Walled Garden, but only added internal IP.
AlG
I also have same problem with my M250 appliance no Access Control and Splash page after the previous update.
Meraki Current version: MX 17.10
Try downgrading It to version 16.16.6
MBWSH
Are these mobile devices with cellular connections?   Try turning airplane mode on and then turning just WiFi back on to verify they aren't using their data connection.  Both Apple and Android devices have settings to failover when their WiFi connection is poor.
Or you can try testing with a device that doesn't have any other internet connection.
