New troubleshooting capabilities
davidvan
Meraki Alumni (Retired)
Hi Community,
Every wireless dashboard user just woke up today with an upgrade in their dashboard this morning. For more, you can take a look at the blog here, or for detailed explanation, take a look at the new documentation page.
We know that across the IT industry, folks are challenged with multiple dashboards, troublesome wireless clients, network & management complexity, and difficulty troubleshooting the network end-to-end. Our goal is to make the user experience seamless, reduce troubleshooting from hours to minutes, and ideally make it proactive instead of reactive.
To summarize the updates:
  1. Client Health. Visually monitor the network end-to-end and pinpoint issues
  2. Wireless Health summary on client page. Quick snapshot of the Wireless Health of a client
  3. Wireless Health summary on AP page. Quick snapshot of the Wireless Health of a AP
  4. Wireless Health 'Connections' tab on client page. Individual Wireless Health problematic connectivity stages of a client
  5. Wireless Health 'Connections' tab on AP page. Individual Wireless Health problematic connectivity stages of an AP
  6. Failed connections event log tab for clients. More easy to read event log for client connectivity failures.
  7. Failed connections event log tab for APs. More easy to read event log for AP connection failures.
Happy for you to post your feedback! Thanks.Meraki End to End Network Visibility.png
14 REPLIES 14
NolanHerring
This is great !
However, since this is still new, I'm expecting bugs. I have a site, full Meraki stack, but I only see the client--->AP--->SW2
When I should see, Client--->AP---->SW2---->SW1---->MX like in your examples
If I do not, should I reach out to support?
Nolan Herring | nolanwifi.com
TwitterLinkedIn
Nash
I'm seeing the same as Nolan: AP -> first switch, then nothing afterward.
However I do like this very much, especially for initial helpdesk troubleshooting when "the wireless doesn't work".
LudwigD
Nice, I really like this.
Much easier for private usage.
Thanks,
LD
GIdenJoe
That's a great step forward!
Request : for the switchlinks would it also be possible to include the link bandwidth usage and packet drops due to QoS?  Qos queue status etc...
I also experience the bug where only the first switch is displayed:
Behind the switch shown there is another MS225 acting as L3 switch, and behind that a pair of MX84's.
davidvan
Thanks for pointing that out @GIdenJoe
You likely have a corner case scenario, as it should be showing the end-to-end view. I've notified the engineering/product teams about this.
We have the same, only the first switch is shown.  The client below has an MX pair as the next hop.  The network is combined and includes the MR, MS and MX
After looking through two networks and fifteen clients I found one that has more than one hop, note this site has the MXs in a separate network.
Here is the topology diagram for the network that doesn't show the MX:
The route for all data traffic is via the MX pair at the bottom that show the STP disabled redundant links, but not the actual live ones.  The diamond at the top labelled MX is the DHCP server that is actually on a different Meraki network and only used for DHCP and the management VLAN.  The diamond at the left doesn't exist (perhaps it is the live MX links) and the Cisco IOS switches that predated the MS stack is also on the topology as shown.
I think if the topology was correct, then the new troubleshooting would flow properly...
antonis_sp
This is a great way to troubleshoot the entire client path if needed.
damienleick
@davidvan
Is meraki plan to add this feature to "wired" client ? It could be very usefull
thanks
davidvan
Anything is possible! We analyze our "Make A Wish" submissions as well, and I've seen that request a few times.
PawelG
In my network consisting of MR45 Ap's the client troubleshooting always shows incorrect chain - client connected to AP and this AP connected then to another. In real all AP are connected to 3rd party switch/router (no LLDP enabled).
It looks like that:
Br, Pawel.
@PawelG
Maybe your first AP si running as a repeater ?
PawelG
Nope, bot are connected to wired network.
When looking at client connected to the other AP it looks exactly the same but with reverse order of APs.
Br, Pawel.
