Moving AP to another network
Egypt
Dear Meraki Support,
kindly support i would like to move APs from a network to another network and both are in the same giografic area but i got ann error
no problem with that error but the secound error i got is
Cannot add an TRA (AE) regulatory domain to a NTRA (EG) regulatory domain network. Add to a new network or contact Meraki support.
even both are in the same
the target network is
7 Replies 7
KarstenI
On network-wide -> General of the new network, how is the regulatory domain configured there?
Egypt
Egypt
Egypt
both is the same and a sample from device to be moved read
KarstenI
I would directly open a Case for that.
PS_Mike
An easy way to do this is create a new network with the regulatory domain set for the destination network you will be moving them to, move the APs to this network and then you should be able to move them to the original destination network, You can then delete the new, temporary network you created. I've had to do this several times and it works like a charm each time.
Egypt
Already did all the steps and all AP be online then tried to move I got the errors up
