Migrating out of NAT Mode
SMANNE
How do we migrate wireless clients from Meraki DHCP(NAT Mode) to an internal DHCP server(Bridge Mode) seamlessly? Any Suggestions.
3 REPLIES 3
DarrenOC
Hi @SMANNE , thinking about this as I type.  The process should be seamless enough:
- create your new L3 interface on your core switch (unless using an existing vlan)
- on the SSID in question switch to bridge mode and enter the vlan tag
- any client connected should re-connect and pick up a new Ip in the new range
you could test by spinning up a new SSID and test the process
What will happen to the unexpired Meraki DHCP leases? Will clients wait until the current Meraki DHCP expire?
I just wanted to make the transition smooth, I thought of reducing the meraki dhcp timer to lowest but that's not an option.
In this case, I'm moving out of the DHCP to a third-party platform not on the Meraki if that makes any difference.
When clients disconnect from the SSID (when the mode is changed) they will then reconnect and request a new DHCP IP address.  You don't have to worry about the existing lease expiring.
