Meraki and Purple
Meraki and Purple
i'm trying to use Purple as my portal hotspot. So i configure that all i need same as guide purple says. but when i connect to SSID, some device laptop or android can't trough automaticly  purple portal, or try to browse website, it is not automaticly redirect to portal.    any suggestion ?
*i attached my SSID configuration.
3 REPLIES 3
Re: Meraki and Purple
Can you post a better screenshot? The image is not really readable.
Spotipo, all in marketing solution. https://spotipo.com
Might want to provide a link to the guide you followed.
From the Meraki point of view, this is the guide to look at to configure EXCAP (External Captive Portal):
https://documentation.meraki.com/MX/Access_Control_and_Splash_Page/Configuring_a_Custom-Hosted_Splas...
From your screenshot I'm wondering whether you performed this step:
Enabling a Custom-Hosted Splash page on the Meraki Cloud
  1. Navigate to Configure > Splash page
  2. Select the SSID you want to configure from the SSID drop-down.
  3. Under Custom splash URL select the radio button Or provide a URL where users will be redirected:
  4. Type the URL of your custom splash page:
  5. Click Save Changes.
Purple will need to be compatible for this to work properly!
Rakesh, here's the OP's screenshot more readable:
Link
This may be of assistance if you have not seen it already:
https://create.meraki.io/build/purple/
