I was also going to agree with @jdsilva , because you would not typically use an access point in this way.
But in this case, I think a Meraki AP could be used for your home Internet connection. You can configure it for PPPoE:
https://documentation.meraki.com/zGeneral_Administration/Other_Topics/Support_for_PPPoE_on_Cisco_Mer...
or DHCP or static IP addressing.
You would need to configure the SSID to be in NAT mode.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/NAT_Mode_with_Meraki_DHCP
The MR has a firewall and traffic shaping.
So yeah, I guess upon reflect, it is probably a very capable home router. Note there are no LAN ports - so you would only be connecting via WiFi.
