Meraki Access Point losing connectivity when acting as a repeater
I have one MR 18 setup to act as a repeater and it's gateway AP is an MR 66 which is approx 105m away. The repeater provides internet to wired devices. This AP loses connectivity randomly for a couple of minutes through out the day. How can i figure out what could be causing it? The 2 are in clear line of sight.
The MR 66 currently has a Dual band omni (MA-ANT 20) 2.4 ghz antenna and Sector (MA-ANT 21) 5 ghz antenna. The event log does not give any information except disassociations and deauthentications. When there is a loss all it shows under connectivity is 'no connectivity'. Also I disabled all SSID's except the one needed on the AP and now two devices are directly wired to the AP but there is still a loss and I cannot figure out why. Power to the AP is running uninterrupted. Could it just be the distance and environmental factors? Is there a way to determine this definitely?
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b743aaae37de0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b743aaae37de0_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b743aaae37de0_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b743aaae37de0_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_3b743aa32cf57a","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
