Last time my network only 1 segment with IP 192.168.0.0/24. and my Meraki AP works fine.
I have 2 SSID : bridge mode & NAT (DHCP Meraki)
Then we implement VLAN in our network, now Meraki AP port in switch already change to VLAN Client segment with different IP (10.10....)
Now the problem is my meraki AP status is offline, i change the Meraki AP static IP address to VLAN CLient segment, but still can not ping (offline)
Somebody help me ?
Solved! Go to Solution.
@barth wrote:With this config, The SSID internal will share IP VLAN Client (11) 192.168.15.0 /24 to user ?
Yes, with that config the packets coming in from the wireless clients will be tagged with VLAN 11 on the trunk, and inversely, the packets coming into the AP via the trunk on VLAN 11 will be sent out to the wireless clients untagged.
I think the problem is that you're actually using the native/untagged VLAN. In my setup you'll see that I don't actually use the native VLAN for anything. Try setting VLAN 11 to tagged as well, and use another random untagged VLAN that you're not actually using.
Also it might also be interesting to know that in NAT-mode, the packets will be tagged with the AP's native VLAN.
What VLAN are you running in the switch as native? Does that match on the accessport?
@barth wrote:Last time my network only 1 segment with IP 192.168.0.0/24. and my Meraki AP works fine.
Somebody help me ?
Yes, Native VLAN Client
"match on the accessport" what thats means ?
I can not reboot, "unreacable device "
I can not ping
any something configuration ?
If the switch is PoE version you can turn off the PoE from port and then turn it on again to reboot the AP
Dear @mtainio
i know and i already try, but still can not ping the static IP, (offline)
What should i do? reset then setup again ?
Another question :
Is the all configuration (ssid, policy, etc) is save in cloud ? so when i reset the AP, the configuration will apply automatically again ?
Hi @barth
All the configuration is saved in Meraki cloud so reseting single AP doesn't affect the SSID's etc.
Is your AP configured to use IP from same VLAN that is configured as native VLAN on the switch port the AP is connected? And are all the VLANs in use allowed in the switch port configuration?
Another way is not to use native VLAN and configure the VLAN in APs IP configuration.
be default, the maraki AP (MRxx) transfers its management traffic over native VLAN (or access port).
if you want your SSID(s) in a different network segment:
1) use Meraki NAT: nothing else is required on the switch (access mode/port is enough)
2) use bridge mode:
2a) configure additional VLAN(s) on your meraki AP switch port (trunk mode).
2b) make sure you have a DHCP server within the additional VLAN(s)
2c) setup the additional VLAN(s) in the 'access control' setting, section VLAN tagging / VLAN id
How is everything setup? Do you have a network drawing? This is how I've set it up for example:
Note that for the switch I set the VLAN both in Switch Settings > Management VLAN and in the IP settings of the individual switch.
Hi, here the simple topology of my new network
Any miss config ?
Hi @barth
Are you using HP Procurve for switches as shown in the drawing?
Have you introduced the new VLAN to the switches and added it to all the necessary ports as untagged?
-Mikko
OTHER SOLUTION
Its works now, i do line my other solution
Thank you for response my thread.
Bye
