Maximum concurrent client connections
On the dashboard I can see the number of current clients on each AP.
Does anyone know if there is a way (on the dashboard) to see the the maximum concurrent connections for an AP?
Thanks,
Gregas
7 REPLIES 7
Re: Maximum concurrent client connections
map & floor plans shows clients for the past day.  I feel like I have seen it somewhere else too.
summary report is the better place you can see them.  You can choose clients per day/week, etc.
EDIT: This is not exactly what you asked I realize now.  I don't think you can see the peak number of clients recorded anywhere.
@BrandonS
I think that shows the total number for that time period.
I'm looking for the maximum amount of concurrent connections rather in the number of clients connected per day/week.
@BrandonS
Thanks again for your suggestions.
I think you are right though, about the peak number not being available.
go to your ap. then go to rf. there you can see cliënts for each radio
Bingo.  That will show max concurrent although you will have to add the 2.4 and 5 users together per AP.
@GregasG I dont think this information is available. I've just had a quick look on my system and can't see it anywhere.
I've also cheked on another vendors system and they don't show that information either and when I think about it its probably to stop people from saying " my AP can handle 500 clients and when I have 495 connected its slow.... but it says it can handle 500 "
