Managing tags
Hammer
Managing tags
Hi.
As far as I can tell with Meraki the same tags can be used for multiple purposes. For example, I can use a tag to assign an SSID to an AP, as well as, using the same tag to assign a VLAN to an SSID which is then assigned to AP. I'd personally prefer to use two different tags.
Is there a way to view all tags that have been used? And maybe where they apply? Can I rename tags? I'd like to go through my tags and maybe rename them to be a little more meaningful, and maybe come up with a way to distinguish between tags used for VLANs and tags used for SSIDs.
Thanks.
Alas only Systems Manager has a tag manager for its tags.
@PhilipDAth That's a pity. Thanks for the info.
Oscpimienta
I think you can use the Cisco Meraki Dashboard API.
Take a look at this: https://documentation.meraki.com/zGeneral_Administration/Other_Topics/The_Cisco_Meraki_Dashboard_API
You can export data so you can manage them as you want.
@Oscpimienta I'll have to investigate that but might be more effort than it's worth, especially with my coding skills.
