MacOS wi-fi logon on login screen AD, RADIUS
Hello.
We prepare computers for new employees.
Each computer has an added administrator account. Then the computer is added to the AD service. allowing to create a mobile account.but when trying to switch user (on the login screen). the computer automatically disconnects the wifi network so it is not possible to log in by the domain user. Even if the network has been connected and stored in the administrator's account.The next problem is that it is a RADIUS network. - which uses the same AD credentials.
So is there any way to force network logon on the login screen using RADIUS  (WPA2 ENTERPIRISE)
2 REPLIES 2
Re: MacOS wi-fi logon on login screen AD, RADIUS
Hi Luke,
if you use certificate authorisation with NPS/PKI, the computer and not the user connect to wifi.
Work very fine!
This is EAP-PEAP network with MSCHAPv2  Authentication.
