MX65 and Cisco Unified Wireless infrastructure
Wilkins
I was wondering if it was possible to have a Cisco Wireless 5520 WC and a Meraki MX65 coexist in the same buildings?
Do I have to adjust the channels on one of the other or is it done seamlessly.
Please advise.
Thanks,
2 REPLIES 2
BrandonS
Do you mean MX65W?  Without the W the MX does not have wireless. I would treat it like any third party AP and either adjust the channels manually or leave them at auto and even consider disabling wireless in the MX if it is not needed for coverage.
best.
Note @BrandonS  post first;
Seamless.  Make sure they are using different SSIDs.
