MX65 Wireless issues over VPN
ChuckH77
I have a MX65 at my house connected to a MX250 via a VPN tunnel.  I am dropping packets over wireless consistently, like 25%.  I am pinging 8.8.8.8 as a test.  If I plug into the MX65 no issues, if I test using my home wireless no issues, but if I connect via wireless to the MX65 I drop 25% or more over the tunnel.  No split tunneling for internet.
The VPN looks solid, latency and connectivity between the MX65 and MX250 is solid green on the portal.  I cannot tell on the portal if there is anything wrong with the MX65.  Any help would be great, I cannot figure it out.
3 REPLIES 3
What firmware version are you using?
... 50 chars....
Hans
Meraki Alumni (Retired)
Just to check before any comment... its a MX65W right?
cta102
Are you getting high (or very variable) response times to the pings which are successful?
