(MX64W-HW) How do I access the functionality displayed in the below part of the attached image?
MicJameson
Hello.
(Please see attached screenshot.) device= MX64W-HW , IOS 16.16
I need to enable SSID broadcasting, yet when I navigate to "Wireless settings" I have very few options.
Thank you!
Ryan_Miles
The second image is when you use standalone Meraki APs. That's different than the wireless settings & capabilities in the MX-W.
2 REPLIES 2
Ryan_Miles
Brash
As @Ryan_Miles said, you're looking under "wireless" which is configuration for standalone AP's.
Configuration for the wireless functionality built into the MX device is under Security & SD-WAN/Teleworker Gateway > Configure > Wireless settings
https://documentation.meraki.com/MX/Wireless/MX_and_Z-Series_Wireless_Settings
