Do all 4 of the MR86 antennas transmit all supported bands of the MR86? or are some dedicated to 2.4GHz and others to 5GHz?
Solved! Go to Solution.
From the installation guide:
"Both 2.4 GHz and 5 GHz client serving radios are diplexed onto each antenna port, so if using multiple antennas it is best practice to aim all in the same coverage area."
Dual–radio aggregate frame rate of up to 2.98 Gbps*
5 GHz 4x4:4 radio and 2.4 GHz 4x4:4 radio offer a combined dual–radio aggregate frame rate of 2.98 Gbps*, with up to 2,402 Mbps in the 5 GHz band and 574 Mbps in the 2.4 GHz band. Technologies like transmit beamforming and enhanced receive sensitivity allow the MR86 to support a higher client density than typical enterprise-class access points, resulting in better performance for more clients, from each AP.
For more details check the documentation.
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MR86_Datasheet
I dont see documentation on frequencies per antenna port.
Refer the installation guide.
https://documentation.meraki.com/MR/MR_Installation_Guides/MR86_Installation_Guide
thank you!
