MR57 - 6GHz Configuration
Andrius
HI
How to enable 6GHz band ?
There is nothing like what is written in the MR57 Installation Guide:
"Under RF Profiles, existing profiles can be modified or new profiles can be created. Then the profile can be edited under the Flex radio selection for MR57. Using the drop-down menu, the 6 GHz band can be chosen for that particular RF profile to support the tri-band operation for MR57"
My meraki profile looks as follows:
The Installation Guide is illustrated as follows:
My country is Lithuania:
MR57 Frequently Asked Questions I find the following:
Which countries are supported for 6 GHz?
Currently the supported countries by the MR57 for 6 GHz at FCS include the US, UK/ EU and Korea. The US and Korea will support UNII 5 through UNII 8 channels in LPI mode. UK/EU will support UNII 5 channels in LPI mode. Please see the approved country list by the Wi-Fi Alliance for most up to date in information on 6 GHz frequency adaption and support.
WIFI 6E is supported throughout Europe:
Did anyone were able to turn on 6GHz on the MR57 ???
My support ticket is still open and no one gives any answer
7 REPLIES 7
What country are you in?  Perhaps you country does not allow it yet.
My country is Lithuania (EU)
WIFI 6E is supported throughout Europe: UK/EU will support UNII 5 channels in LPI mode
WB
Sounds silly but I am assuming you're running 28.6.1 firmware on the MR57?
I'd hit up your Meraki rep/support to find out why you can't enable the 6 GHz band given the EU has adopted a portion of the spectrum
Andrius
Yes, Current version: MR 28.6.1
I registered a case, but a month has passed and I didn't get any answer why
Possibly an r29 feature, I'd check but I don't have an MR57 at the moment...
robnils
Same here. We opened a case on May 10 and the only updates we get is that it's "investigated internally".
Really disappointing...
Andrius
Finally, after update
