MR55 protective enclosures
Does anyone have any recommendations for protecting MR55 units in a gymnasium?  Would prefer something that allows for wall-mounting unit, but flush mount would be better than nothing.
Even a pointer towards available enclosure manufacturers would be helpful.
TIA
2 REPLIES 2
Re: MR55 protective enclosures
Here are some options but with the MR55 being so new I'm not expecting any specific 'for that exact model' options available.
Not saying all or any of these fit the bill but these might be some options:
http://shop.acceltex.com/index.php?cPath=30
http://shop.acceltex.com/product_info.php?cPath=93&products_id=279
https://www.ventevinfra.com/shop/right-angle-bracket-for-nema-enclosures-p-4044.html
https://www.ventevinfra.com/shop/wifi-enclosures-ceiling-surface-mount-indoor-only-wall-brackets-mou...
https://oberoninc.com/products/surface-mount-enclosures
You'll want to validate before purchasing anything of course if the MR55 will fit (since I know its somewhat of a big boy itself).
Nolan Herring | nolanwifi.com
TwitterLinkedIn
@NolanHerring has some great suggestions.
I would think any ABS plastic electrical enclosure would be fine.  If you are getting a cabling person in to install it (or at least run the cable) I would ask them to install such a cabinet to put it inside of.
