Since the MR55 has a dedicated 3rd radio for location tracking does it need to be installed in the same orientation (facing the same wall) like the mr 84 that has the arrow on it for installation?
Solved! Go to Solution.
https://documentation.meraki.com/MR/Installation_Guides/MR55_Installation_Guide
Check this doc. Look for "Installation Instructions" 😊 it should have different scenarios.
I have read this and it doesn't speak to specific orientation so I guess there isn't an orientation. thank you for the quick response
where did you read the 3rd radio does location tracking?
In the data sheet for mr55 it states location analytics
thank you all for your response.
