MR53 not showing SSID after Firmware update
Recently I've updated my networks from Firmware MR25.11 to MR25.14 now it seems that on some of the MR53 our guest SSID does not appear but after restarting the AP it reappears. I thought at first it was just an isolated instance but now finding that more and more of them in two different networks are experiencing the same issue. I have seen there was a post sometime back with a similar instance on the MR42 and the solution was to upgrade firmware to MR25.11. Is anyone else experiencing this?
Accepted Solutions
Re: MR53 not showing SSID after Firmware update
We have gone to 26.6 and so far so good, no further reports of issues.
13 REPLIES 13
Might be a known bug. Did you by chance open a case with support to confirm?
Might want to take a look at 26.6 for the MR53 model, I had to use 26.X train for my MR52 so I'm assuming the same would apply for MR53
Nolan Herring | nolanwifi.com
TwitterLinkedIn
There was a bug which required all configured ssids to have the save minimum bit rate on the same AP.  Have you got more than one ssid and using different minimum but rates?
No all SSID's are configured with the same bit rate.
Thanks, I'll look into that and test it on one of our smaller networks and see if anything else breaks or if that will do the trick.
I have got many MR33, MR34, MR42, MR42E and MR52. Suddenly one of the SSIDs disappeared from some of our accesspoints. The accesspoints running MR25.14 software.
After rebooting the SSID appeared again.
I opened a case and sent some pcap-files. the answer was: this is a known problem and might be better with MR26.6 software.  So I will update my accesspoints at chrismas and see whats happening.
Just for peace of mind, we have all the models you have (with the exception of the MR42E) on our networks that are happily running 26.6.
Glad I convinced myself to stay on 25.13 then.
They should remove 25.14 as stable if 'that' is a known issue. That issue alone makes the AP useless.
TwitterLinkedIn
Yeah, I agree it's not even listed as a known bug, I rolled my networks back to MR25.13 this morning and will wait till after this week and start rolling out MR26.6 next week one network at a time and see how that works. Thanks for you input.
Same issue here on 35 networks with 25.14, got corp and guest SSID and randomly some laptops cannot see the corp SSID, but can see the guest with full strength. Raised a case and appears to be a known issue and to upgrade to 26.6, which I am in the process of doing now. Echo the comments above at how 25.14 got to stable release.
I opened a case with Meraki about this bug more than 2 months ago. Cann't understand why 25.14 still is marked as stable version
pjc
Was considering moving from 25.13 to the latest 'stable' 25.14 version...
Random disappering SSiD's ?  Think I'll pass.
My plan is to do a few networks one at a time to move towards 26.6 and see what happens.
