Search instead for
MR52 and MR53 ports
MR52 and MR53 ports
can the second ports on these AP be used for downlink connectivity like Apple TV or printer etc, if yes is there a documentation on usecase ?
13 REPLIES 13
Re: MR52 and MR53 ports
Nope
That second port is for bonding both ports together via LACP, you know, for that elusive unicorn of being able to go over 1Gbps on wireless. Insert 'el oh el' symbol here.
https://documentation.meraki.com/MR/Installation_Guides/MR52%2F%2F53_Installation_Guide
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/MR_Link_Aggregation_Configuration...
Nolan Herring | nolanwifi.com
TwitterLinkedIn
You're clearly not using 80MHz channels.
Smiley Very Happy
Thanks I saw that, so you are saying it can only be used for bonding and not individually for downlink connectivity ?
have you tested it, unfortunately I don't have one of these APs to test.
@jdsilva  You sir are correct, at least not for enterprise. Rocking it at home, but I don't have any 3-stream clients, or 4 stream clients (not sure who does) and/or crystal clean RF always 5 feet away from my device =).
Actually...the datasheet for the MR53 touts that it can do 160MHz. Where? I see no option for this, not that I have any clients that support it. just curious
@ammahend I have not tested this, I am strictly going off the documentation. If it is/was possible, I would imagine that they would say so. If its a secret, then its a sneaky one.
TwitterLinkedIn
Good find @BrechtSchamp
Wish they would specify which model supports that. Unless that is some really old document from long ago.
I'm sure it 'CAN' be done via software though, if they wanted to.
TwitterLinkedIn
Good link @BrechtSchamp , but I see a devil in the detail there:
"The wired port of an Access Point acting as a repeater"
I think the way you need to read that is that APs with one port can also do it, but only if functioning as a repeater (which is obvious because otherwise the port is in use).
That said, the reason I said it might work is exactly this, I haven't tested it.
Actually the second port can be re-configured, but it can only be done by support, and you have to open a ticket to do it.  On the whole it is a pain in the arse, so I wouldn't do it unless you already have the kit and really need to.
If it is a for a small low density area, have you considered using the MR30H?
https://meraki.cisco.com/products/wireless/mr30h
https://meraki.cisco.com/blog/2018/03/auto-rf/
"although 160 MHz is not suitable for enterprise deployments or supported in the Meraki dashboard."
@jdsilva
What the heck lol.  Well thanks for finding that for me.
TwitterLinkedIn
thank you all for your response, you are right, this ia a beta feature and have to engage TAC to enable it.I got to know from one of the SE.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/Port_Profiles#Applying_profiles_t...
Thanks for the feedback. I wonder if it works without the port profiles feature though. In other words, if you're okay with having one global setting that determines what happens when you wire up a client to an AP. The way I see it the port profiles feature allows extra configuration, i.e. specifying VLAN per port per AP.
From that link it's also mentioned that the global setting would be ignored for the MR52, MR53 and MR84 once that's enabled.
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
