MR52 Outdoor but well sheltered
RumorConsumer
I have a need to put an AP in a little hut in my garden that has power and i can get Ethernet over power well to the location. It won’t be getting rained on or anything, just maybe changes in relative humidity when it rains. Anything to be concerned about?
4 REPLIES 4
Bruce
Datasheet says humidity from 5% to 95% so long as it’s non-condensing, so sounds good to me. https://meraki.cisco.com/product-collateral/mr52-datasheet/
GIdenJoe
There exists something like a NEMA closure.  But I'm not sure if that won't drive the price too far up 🙂
@RumorConsumer as long as inside the hut doesn't go over or under the operating temperature and humidity ranges then you should be fine.  I'm installing an AP in a log cabin in the garden but I'm insulating it first so it doesn't get too hot or too cold and the humidity is more like a normal building.
If you don't or haven't insulated the roof in particular, I'd put a sensor in there, even in the UK, without insulation the cabin in my garden went over 36C(97F) in the summer, insulation just of the roof dropped that to mid 20s (75F).
The MR52 maximum supported environment operating temperature is 40C(104F)...!
RumorConsumer
Ok good to know. I think i will be in range
