MR33 and Proxim Orinoco Ap-700's
FBA2804
Just browsing
We are deploying MR33 AP's throughout our sites.
When we install a MR33 we see our old legacy Proxim Orinoco AP-700 AP's losing wireless connectivity.
We also have some old Cisco1242AG AP's installed, these don't experience this problem.
If I disconnect the MR33 from the network , the Proxim's are fine.
Any help / advice appreciated.
2 REPLIES 2
Steinbep
Are you using the same SSID?  If so look at Wireless, Air Marshal and white list the SSID.  Capture.JPG
Make sure you avoid using the same SSID's on the new and old kit at the same time.  It will cause you issues.
