MR33/MR42 and Cisco Unified Wireless infrastructure
Wilkins
Can the Meraki and the WLC coexist and not interfere in each others channels? Can I manually configure the channels in one or the other?
Please advise.
Thanks,
JW
2 Replies 2
NolanHerring
They would act just like any other vendor, as neighbors. If they are going to be broadcasting the same SSIDs etc., you'll want to whitelist each other on both ends.
Channels if you leave RRM/Auto-RF alone, they should 'settle' hopefully, otherwise if you want to you can also statically configure the channels.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
I agree with @NolanHerring you can set the channels manually under "Radio Settings" in the "Wireless" section of Meraki but I would leave it AUTO.
Enthusiast
