MR33 AP can't ping Laptop
ADero
We have a MR33 AP delegating IPs from a DHCP server.  The laptop I'm using can ping the entire network, however nothing on the network seems to be able to ping back.  We can reach the AP just not anything that is sitting behind it.
6 Replies 6
You might have client isolation enabled on the SSID
I did check this verify that it is currently disabled in the options.
Is something not working?
Or just a ping from any client to your laptop?
Is your ssid in bridge mode?
DensyoV
Try disabling your Windows firewall and see if that works. Also, check if you have any layer 3 firewall rules configured on the Wireless > Firewall and traffic shaping page.
Thanks,
Please hit kudos if you found this post helpful and/or click "accept as solution" if this solved your problem.
Nash
@DensyoV wrote:
Thanks,
This is very good advice. Windows firewall likes to block external pings.
You can test for Windows FW issues by confirming the AP is pingable by another device on the same SSID. Then try to ping the AP from the problem child device. If problem child can ping AP, but AP can't ping problem child, it's usually software firewall.
Jwiley78
Not sure this is the problem but under Wireless -> Firewall
