MR30H won't allow access to VLAN
Lockdown502
Hi all. New here and new to Networking. I have a Meraki MR30H that was allowing access to Business VLAN up until a couple days ago. Now the clients are failing authorization to RADIUS. Test device has 39db signal strength. Other VLANS are fine (Guest, etc) and other APs are fine. Power cycled the port that the AP was on. Client will pop up with IP 0.0.0.0 and try to connect but won't.
Any help is appreciated and let me know what info I can provide. Thanks!
3 REPLIES 3
Re: MR30H won't allow access to VLAN
I would check Organization/Change Log, and see if there were any changes in that time period.
Next, I would check the RADIUS server and verify it is allowing access.  If it is not check the reason why access is not being granted.  The answer will lie with the RADIUS server.
Lockdown502
Thank you. I was on the right path, however I don't have access to our RADIUS server yet so I'll involve the Network Manager.
Thanks again!
Lockdown502
Found the solution. The key entered for the SSID was incorrect on the Meraki Dashboard. My Network Manager fixed it and the problem was solved. Thanks for all the help it assisted in eliminating user error!
