MR30H User Limit!
khurram
MR30H User Limit!
How many user can serve by MR30H at a time?
6 Replies 6
AjitKumar
Hi Khurram
Did you get a chance to go through the following Url
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Approximating_Maximum_Clients_per...
It seems,
Each access point has a technical limitation of 128 clients maximum per radio. Please note that this is only a theoretical maximum; in practice, interference caused by multiple clients communicating simultaneously will cause this limit to be far lower.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Thx for the reply. Kindly help me in one more thing how to download the CSV file of location Analytics? and how to integrate it with any other server like CRM?
@AjitKumar wrote:
Hi Khurram
It seems,
You really should start a thread since this is a completely unrelated question.
Next to each type of info in Location Analytics is a "CSV" button to download the data in CSV format.  You'll need to talk to your CRM people to find out how to integrate this data with their platform.
Thx for the reply i am hitting CSV button but nothing is happening.
I just tested it using Chrome and it worked.
thx it work.
