MR and Cisco AP signals
RIT
Did any one install Meraki and cisco access points in the same building? I need to install both in the same building but each one belong to a different network and different SSID, I am wondering if the wifi signal will get effect. Can you please help me with this.
3 REPLIES 3
Inderdeep
@RIT : If they are setting up near by you can get the interference
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Common_Sources_of_Wireless_Interf...
Regards
Inderdeep Singh
www.thenetworkdna.com ( Awarded by Cisco IT Blogs award 2020)
what if manually change the channels for Meraki to use different channels that in cisco? is that will help?
UCcert
no reason why both platforms couldn't be tweaked to avoid channel overlaps.
Darren O'Connor | uccert.co.uk
