MR 76 feature point to point between building to building
Mike12
I would like to check with community for the solution to extend the wifi coverage between building to building.
I saw there is a point to point feature for MR 76 in the MR data sheet. I would like to use this feature to cover the warehouse building from the main office building without extending the cables to warehouse.
Can someone explain it to me or share the setup for the point to point?
Thanks,
Mike
jbright
These document may be helpful too:
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Extending_the_LAN_with_a_Wireless...
https://documentation.meraki.com/MR/Deployment_Guides/Mesh_Deployment_Guide#Multi-VLAN_support_over_...
MR firmware 28.1 brings the ability to support multiple VLANs over a wireless mesh connection.
Take note that you must still contact support to turn this feature on for the specific network.
2 REPLIES 2
DarrenOC
Hi @Mike12 , believe you’re looking at Wireless Mesh Networking.  Info below
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Wireless_Mesh_Networking
jbright
