MR 27.4 released, plenty of fixes
But as @PawelG noted, authentication errors still not fixed...
6 Replies 6
DarrenOC
Hi Charles.  You noted this one?
  • Downstream VOIP RTP Packet Loss (MR42/MR42E/MR52/MR53/MR53E/MR84)
@DarrenOC it's been there for ages, in fact I can't remember when it wasn't a known issue!
Edit: it appeared in 26.5...
CptnCrnch
Smooth upgrade on MR42 and MR45 so far! 😎
Adam2104
How is this still not fixed?
This has been broken for at least 18+ months. It makes Facetime calls absolutely unusable. The only workaround it to reset all DSCP values on the switch side to (presumably) prevent the traffic from landing in whatever queue on the AP is jacked up.
thomasthomsen
Its nice to see that something is being done about the wired MR30H ports.
There are still some strange issues, perhaps this fixes it.
27.4 is now a stable release candidate! Well deserved IMO, the 27.3 and 27.4 releases have both been rock solid. Really a no brainer for WiFi 6 APs but even on my MR53 the performance has been more consistent.
