MA-ANT-3-F6 wall mount or gang box mount?
greaper
Does anyone know if the MA-ANT-3-F6 will flush mount to a wall or mount to a 4 inch square electrical gang box without additional mounting hardware?
Thanks, Seth
1 Reply 1
Raj66
Hello @greaper ,
Sector Antennas are a bit difficult to mount but with proper mounting brackets, you can flush mount them to walls. It is hard to mount them without proper mounting gear, also not advisable, especially if it is an outdoor setup. Wind might come into play and change the antenna alignment.
Cheers!
Raj
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
