MA-ANT-25 Antenna Not Diffusing Signal
antmich
Hi everyone,
I'm currently deploying MR74 APs with the MA-ANT-25 antennas (2 per AP). Whenever i try powering up the AP, it turns green but I see no SSID in the air. It is supposed to be a survey mode AP and is connected to my battery pack.
Any idea of what could be wrong ?
Thank you very much
Hi @rhbirkelund !
I ended up finding what the issue was. The AP was in survey mode as expected, but for some reason the broadcasted SSID was hidden ?
I haven't found why and couldn't configure it differently, so I just kept going my survey knowing the SSID was hidden.
2 REPLIES 2
rhbirkelund
Have ensured the AP is configured in survey mode?
See here for instructions; https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Conducting_Site_Surveys_with_MR_A...
Hi @rhbirkelund !
