MA-ANT-23 - Water/Weather Proof ???
Matt_Collins
Hi Fellow Merakains,
Just a quick questions and confirmation, Looking at the MA-ANT-23 with a MR76 for outdoor usage, I know the MR76 has an IP Rated casing but when looking at the MA-ANT-23 data sheet there is no mention of an IP Rating and it is it actually weather and waterproof.  I assume that it is as the MR76 is and the ANT-23 are designed for the MR76, There is nothing on the datasheet apart from Temp Range.   Just me being cautious and double checking.   Can somebody advise or point me to a Meraki docuement that has something about the water/weather proofing
Many thanks
1 REPLY 1
DarrenOC
Here you go:
https://documentation.meraki.com/MR/Other_Topics/Frequently_Asked_Questions_regarding_Cisco_Meraki_A...
What are the Models of Outdoor Antennas?
MA-ANT-20 Meraki 4dBi/7dBi Dual-Band Omni Antennas, set of 2
MA-ANT-21 Meraki 5 GHz MIMO 13 dBi Sector Antenna
MA-ANT-23 Meraki 2.4 GHz MIMO 11dBi Sector Antenna
MA-ANT-25 Meraki Dual-Band 8dBi/6.5dBi Patch Antenna, set of 2 (if using with 4x4:4 APs)
MA-ANT-27 Meraki Dual-Band 9dBi/12dBi Sector Antenna, set of 2 (if using with 4x4:4 APs)
AIR-ANT2513P4M-N Cisco Aironet Four-Port Dual-Band Polarization-Diverse Array Antenna (Stadiums)
