Looking for a way to get Total unique users and hours used across all wireless networks for a year
Hi Folks,
I've been asked to report on the following for the previous Australian financial year (1 July 2018 to 30 June 2019)
* Total number of unique users for all wireless networks associated with our organisation
* Total number of hours used for all wireless networks associated with the our organisation
I'm looking through the available tools on our meraki instance (note that we don't have a syslog server, which seems like it might solve this issue) and I've hit the following obstacles:
 the summary report tool only allows me to select data for about a 6 month period, which means the "unique users for a year" value wouldn't be accurate (i.e. if I ran two separate reports for the two 6 month periods it wouldn't be unique users for the whole year)
* there doesn't seem to be a raw count of hours used in any of the built-in reports
Is anyone aware of a way to obtain this from the delivered tools/reports on either the meraki dashboard or via APIs?
4 REPLIES 4
Re: Looking for a way to get Total unique users and hours used across all wireless networks for a ye
Hi @Tommyrot
I understand this may not be possible.
I believe "syslog" was the answer.
Summary Reports gives us very minimal information. APIs again talks to Dashboard for information, which I understand is maintained only for 30 Days.
Cheers
Ajit
ajitsnw@gmail.com
https://www.linkedin.com/in/ajitkumarverma/
You can't.
Here is a blog post with some more info about data retention, but like others said, nothing goes back 1 year
https://www.willette.works/meraki-event-logs/
Nolan Herring | nolanwifi.com
TwitterLinkedIn
Thanks very much for confirming this everyone.
Good to understand a bit more from that https://www.willette.works/meraki-event-logs/ article, thanks @NolanHerring
