Is meraki MR20 supports SSO or not ???
Mayurf5techno
hi Guys,
hope you're doing good !!!
3 REPLIES 3
UCcert
Hi @Mayurf5techno , SSO isn’t hardware dependent so you should be fine.
What are you using for SSO?
Darren O'Connor | uccert.co.uk
Mayurf5techno
hi thanks,,,
we wants to use sso for ssid authentication.
SSO with Active Directory will work (as in, you log into your computer, and then authenticate against WiFi without user intervention).  You need to use WPA2-Enterprise mode and have a RADIUS server.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_...
If you mean SSO against SAML, no.
