Is it possible for MR42 to distribute DHCP Address to LAN clients?
GerardC
Currently our ISP Modem, Meraki MR42 and LAN client are patched into a Dell N3048P switch. ISP Modem and Meraki MR42 is assigned to VLAN 200, where the AP receives an IP to match the public IP from ISP Modem. LAN client and the AP are assigned to VLAN 201, in which the AP's native VLAN is 200.
1 Reply 1
Only wireless ones, if you had a 2 port AP the second LAN port might be able to be fed to a switch, but not on an MR42
